VeriStand
xsd for system definition
Where can I find the XSD file to create a system definition for veristand 2010 ?
Thanks for answer.
Message 1 of 10
(8,251 Views)
And thanks for posting here.
Do those links answers to your question or do you look for an other file?
http://forums.ni.com/t5/LabWindows-CVI/IVIConfigurationStore-xsd/m-p/1420972?requireLogin=False
http://forums.ni.com/t5/Switch-Hardware-and-Software/What-is-the-xsd-file-in-C-Program-Files-IVI-Dat...
Jérémy C.
NI France
Message 2 of 10
(8,227 Views)
Thanks for your answer but I don't find the file that I am looking for.
I need a XSD file or a specification to create the *.nivssdf file  without using the System Explorer Interface.
Message 3 of 10
(8,221 Views)
Is your idea similar to this post?
http://forums.ni.com/t5/NI-VeriStand/Modify-the-VeriStand-System-Definition-from-LabVIEW/m-p/1709408...
Which version of Veristand do you use?
Jérémy C.
NI France
Message 4 of 10
(8,214 Views)
All of the .xml and .xsd files used by NI VeriStand can be found here (Windows 7/Vista...I'm not sure what the XP path is):
C:\ProgramData\National Instruments\NI VeriStand 2010
I believe the specific .xsd you're looking for would be:
C:\ProgramData\National Instruments\NI VeriStand 2010\System Explorer\System Explorer Definition Files\System Explorer.xsd
However, I wouldn't recommend manually editing .xml files, since this is very prone to error.  As Jeremy mentioned, NI VeriStand 2010 already has a public .NET API available which is used for creating / editing system definition files.  VeriStand ships with an example of how to use this API in LabVIEW, but you can use it in any programming environemnt that supports .NET.  You can find the LabVIEW examples on your system here:
<LabVIEW 2010>\examples\NI Veristand\API\System Definition API
Devin
Message 5 of 10
(8,117 Views)
Thanks.
Does a public API ( which is not .NET ) exist ?
Message 6 of 10
(8,111 Views)
No, all of NI VeriStand's APIs are .NET only.
Message 7 of 10
(8,109 Views)
Thanks for answers
OK. Where can I find this API and documentation ?
Message 8 of 10
(8,093 Views)
The API can accessed by referencing NationalInstruments.VeriStand.SystemDefinitionAPI by using a .NET contructor node in LabVIEW.
The API is documented in NI VeriStand 2011 under NI VeriStand .NET Reference.
~ Olivia
Message 9 of 10
(8,078 Views)
The NI VeriStand APIs are registered with the GAC (Global Assembly Cache) when you install NI VeriStand, so you should be able to find them by browsing the GAC from .NET environment (ex. LabVIEW).
The available public APIs are:
NationalInstruments.VeriStand.ClientAPI
NationalInstruments.VeriStand.WorkspaceMacro
NationalInstruments.VeriStand.RealTimeSequenceDefinitionApi (2011 only)
Unfortunately documentation for the APIs did not make it into NIVS 2010 (although you can find documentation for the Client/Execution API online here).  If you upgrade to NIVS 2011 though, it includes the documentation for the System Definition API.
Devin
Message 10 of 10
(8,075 Views)
