VeriStand
multiple projects on one PC
If, for example, I have two independent VeriStand projects each with its own real-time target can I run both projects while maintaining a connection to both (via the VeriStand 2021 R3) using a single Windows Desktop PC?
(133 Views)
Currently only one instance of the VeriStand Gateway can run on a Windows PC host. The Gateway can only communicate to multiple real-time targets if they are in the same VeriStand System Definition.
It is possible to silently disconnect/connect the Gateway to switch communication between different real-time targets, but the Gateway can only exchange data with one target at a time unless they are in the same project/sys def.
Another option may be to use a separate virtual machine to handle each VeriStand project. This would be two separate Windows environments but you could use a single physical PC.
Reference: Solved: Re: Run Multiple Projects Simultaneously on one host PC
To my understanding, this statement is still valid with the latest VeriStand 2024.
Control Lead | Intelline Inc
(99 Views)
