VeriStand
.dll rate
I have compiled  a model in simulink the rate of the model is 4 hz when I add the model in NI Veristand in Model Simulation info I see 4 Hz but in model setting I could see 100 hz that means in case I execute the model is going to run at 100 hz ? faster than the model in simulink or is going to run at 4 hz?
(5,637 Views)
If you set the rate to 100Hz, the model will attempt to execute at 100Hz.  If you need 4Hz, try setting the decimation to 25 in model settings.
(5,487 Views)
