VeriStand
cDAQ 9205 won't show in Veristand
I recently purchased a cDAQ 9205 module that is installed in a cRIO 9056 chassis. Everything works in Flexlogger, but I need to use Veristand so I can run custom models alongside the I/O.
When I run NI MAX, the 9205 shows up as a DAQmx device and the test panels work fine.
When I run the hardware autodiscovery wizard in Veristand, the 9205 is not found (although another module that's installed in the 9056 chassis works fine).  If I try to manually add a DAQ device, it gives an error on deployment that the device can't be found.
Is there any way to make this work??  My undersanding was that modules supported by DAQmx would be supported in Veristand.  I've tried in Veristand 2019 and 2020 with no luck.
Message 1 of 1
(3,168 Views)
