VeriStand
When I am deploying CD to Linux RT, The error occurs like this
Background:At the beginning, I generated a CD project through the official NI custom device template tool, and found that if it is to be deployed to NI linux RT, some additional settings and modifications are required.Then I spent a lot of time on it , and Then I succeed. But I found if the CD is the empty one ,then I can succeed to deploy it. but if I add some channels, and some computation in it (main page.vi/ installation.vi/ RT driver.vi). it will have this error:
here is the linux RT side:
the whole error expanded are :
Deployment Error
Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
<append>=========================
NI VeriStand: NI VeriStand Gateway.lvlib:VeriStand Server Wrapper.vi >> NI VeriStand Server.lvlib:NI VeriStand Server.vi >> Server TCP Interface.lvlib:TCP Send Target Message.vi:890001
NI VeriStand: NI-PXIe-8861-03269D81
Error -307682 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
Possible reason(s):
NI VeriStand: Could not complete one or more requests because a target is offline.
So I don't have the direction to fix, I only add some simple stuff on my CD project.So can you please help me to analyze this issue? it is really urgent for me. Thanks.
Message 1 of 1
(78 Views)
