VeriStand
Veristand frequency
You might have other cards that are preventing your main loop from running at the speed you want.  This would be preventing the counter from running at it's full speed.  I would suggest that you pull your ctr cards out to a separate loop in your FPGA so it can run at max speed, then pass your DMA loop a local var from your ctr loop to pass up to VeriStand.
Message 11 of 12
(962 Views)
I have a separate loop for the counter measurement.
Message 12 of 12
(939 Views)
