VeriStand
Veristand TreeBrowserWF Display Filter
Try casting the item to a channel type. if that throws an error... probably not a channel
Stephen B
Message 11 of 14
(3,764 Views)
I found the solution. Convert Callback to DBLClick.vi  from the VI.LIB has a parameter Return Meet Filter Selection, if this is set to TRUE, I get the behavior I was looking for.  The parent folder will expand on a double click, and the root channels can only be selected.
Message 12 of 14
(3,754 Views)
Awesome! Glad to hear it. If you dont mind can you post the final VI for others to learn from?
Stephen B
Message 13 of 14
(3,750 Views)
Here are the code solutions to the 2 issues that were discussed.  Thanks for all the support.
This is the code for the Custom Filter.
This is the Code for the double click event.
Message 14 of 14
(3,745 Views)
