‎05-09-2012 10:37 AM
Try casting the item to a channel type. if that throws an error... probably not a channel
‎05-09-2012 06:36 PM
I found the solution. Convert Callback to DBLClick.vi from the VI.LIB has a parameter Return Meet Filter Selection, if this is set to TRUE, I get the behavior I was looking for. The parent folder will expand on a double click, and the root channels can only be selected.
‎05-09-2012 07:11 PM
‎05-10-2012 09:29 AM
Here are the code solutions to the 2 issues that were discussed. Thanks for all the support.
This is the code for the Custom Filter.
This is the Code for the double click event.
