01-28-2010 06:27 AM
I am new to veristand and i tried to add a DAQ device, simulated in MAX. But no reponse of the simulated device being detected by Veristand. In short can any one help me in explaing how to add a DAQ device, simulted in MAX, to veristand and test the functionality of the DAQ. I tried simulating 6052 MIO card. So, please try explaining me with the same device.
01-28-2010 10:02 AM
Are you running your configuration on a PC or on an RT Target? VeriStand 2009 only supports HW I/O such as CAN, DAQ and FPGA on RT Targets. You can configure hardware for a configuration targeted to localhost, but it will be ignored. This has nothing to do with the fact that the DAQ device is simulated.
If you simulate a DAQ device on an RT Target from MAX, then you can access it successfully from VeriStand by adding a DAQ board in System Explorer with the same device name.
The primary motivations for not having HW I/O on Windows are:
01-28-2010 11:04 PM
Thanks Jarrod. I am running veristand in a PC and i don't have any real time targets as of now. So, my study of veristand is fully on PC alone. Jorrod, you mean to say that if a plug in a DAQ card in PC mother board's PCI slot - it cannot be accessed in veristand?
In that alarm configuration screen, we do have a option to log alarm trips right? But where does the alarm trips get logged and what and all will be logged when a alarm trips?
I saw a file in the folder named Logs in the path
C:\Documents and Settings\All Users\Documents\National Instruments\VeriStand
but in that only logging in and closing the windows are being logged.
Please help me.
Thanks.
02-08-2010 09:51 AM
Hey Vino,
That is correct. The PCI DAQ card will not work with the NI VeriStand engine running on windows. If you require this functionality, a custom device can be written to enable it.
The log trips button will log the alarm and alarm time upon a trip to the C:\Documents and Settings\All Users\Documents\National Instruments\VeriStand\Logs folder on your machine.
Take care,
