VeriStand
VeriStand error
Due to a change of location, my computer on which VeriStand was running had to be completely reset and now the old VeriStand project is no longer running and gives the error message, you can see in the attached screenshots.
As a hint: A LabView model is integrated, could this be the reason?
Kind regards
(3,156 Views)
Accepted by topic author mihamm
Only for information:
I have the solution now. The problem was that different versions of NI VeriStand were installed on my PC and the PXI system to be controlled, so the project could not be deployed.
(3,058 Views)
