VeriStand
VS2018sp1 Model generation for linux not selectable
Hi
we are upgrading different testbenches, in our company from LV2015, VS2014 to LV2018sp1 and VS2018sp1.
now for certain benches we are using a compact-RIO 9039. and as result we need to recompile the models.
problem is we can't select the Linux x64 OS from the list.
we have installed eclipse and reinstalled veristand and the model framework, as the order could influence the stuff installed.
but to no avail. the solution as provided in the knowledge database. doesn't work as it only forward to VS2019
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8ucSAC&l=nl-BE
and not to the VS2018 tool that i actualy need for compiling the models
thanks
with kind regards
Anthony Misseeuw
(2,026 Views)
Accepted by topic author Aboughton
Hi Anthony,
You are completely correct, the steps in that knowledge article should resolve the issue for you. However, the download for "NI VeriStand LabVIEW Models for NI Linux Real-Time Targets" has gone down, but we are working to get them back up online. If you cannot find the download page, please contact NI Support
Please note that the 2018 version of this software is compatible with 2018 SP1 Veristand.
Thanks!
Alice
(1,964 Views)
