VeriStand
Unable to compile dll when using reference models and parameters
I have a simple model that uses a reference model and a Simulink Parameter that is intended to be tunable.  The code generated from this looks obviously incorrect and generates build errors during compilation.  If I do not include the Simulink Parameter I get proper code and can compile but that does not meet the needs of my application.
I attached the example models and the a log file that shows the errors.
Here are some lines of code in the ni_pglobals.h that seem obviously incorrect which are being flagged as errors:
#define top_level_P.const_1 NI_PARAM_BUFF.top_level_P.const_1
#elif defined(_NI_UNDEFINE_PARAMS_DBL_BUFFER_)
#undef _NI_UNDEFINE_PARAMS_DBL_BUFFER_
#undef top_level_P.const_1
#endif
(755 Views)
I installed the latest toolchain and see different results but it still fails to compile.  I included zip files using 2019 and 2021.
(720 Views)
