VeriStand
Template custom device DSA
I'm reading RMS signals from accelerometers, but I wanted to get the pure signal directly. To do this, I need the custom device DSA template. Could anyone tell me where I can find this template (.vi), or if it is a driver that I install directly on the veristand.
Thanks!!
(766 Views)
If you want to get the original signal but not the computed value, use the voltage input task instead of the accelerometer task.
https://tmesystems.net/
(737 Views)
Thanks, I'll try this.
(731 Views)
