08-22-2012 07:16 PM - edited 08-22-2012 07:17 PM
This is a follow-up on this post.
I create several sequence calls on a given sequence, each with different parameters settings:
then I start them all in parallel:
Are all sequences starting in sync, or one after the other ?
Thx.
L.
Solved! Go to Solution.
08-23-2012 09:53 AM
All sequences started together in a session running on the same target will start on the same timestep. They are synchronized.
08-23-2012 10:10 AM
Thx Jarrod.
L.
