VeriStand
Playback of an array from labview
My workaround was to edit MaxItemsInObjectGraph in machine.config
under system.serviceModel I added
<commonBehaviors>
	<endpointBehaviors>
	<dataContractSerializer maxItemsInObjectGraph="2147483647"/>
	</endpointBehaviors>
	<serviceBehaviors>
	</serviceBehaviors>
</commonBehaviors>
then I had another error regarding .NET, and I figured out it was about some buffer size, so I added to system.serviceModel in machine.config
<bindings>
<netTcpBinding>
<binding name="netTcpBinding" closeTimeout="00:10:00" openTimeout="00:10:00" sendTimeout="00:10:00" listenBacklog="100" maxBufferPoolSize="2147483647" maxBufferSize="2147483647" maxConnections="100" maxReceivedMessageSize="2147483647">
<readerQuotas maxDepth="2147483647" maxStringContentLength="2147483647" maxArrayLength="2147483647" maxBytesPerRead="2147483647" maxNameTableCharCount="2147483647" />
</binding>
</netTcpBinding>
</bindings>
Anyway, your solution is way better, as editing machine.config is something I'd like to do only on my machine.
As a suggestion: would it be possible for the veristand .NET API to handle these exceptions, and eventually to give me the option to edit this parameters in the code, like I do in other languages?
Matteo
Message 11 of 12
(3,237 Views)
VS2011 SP1
We have experienced the same issue. Modification of machine.config works. Knowing the WFC for the gateway can be tuned by "C:\ProgramData\National Instruments\NI VeriStand 2011\NIVeristandService.xml", is it possible to specify the new quota into this file instead of machine.config ?
attached: our current NIVeristandService.xml settings.
Best Regards
Message 12 of 12
(3,087 Views)
