VeriStand
PXI-2510 has no reaction while using NI VeriStand
Hello all,
I want to use a PXI-2510 in NI VeriStand and I read a document named NI VeriStand Add-on - NI Fault Insertion Units at: http://zone.ni.com/devzone/cda/epd/p/id/6248
After deploy, I change state of controls in workspace, but PXI-2510 has no reaction.
The following is my step:
1. download the file-2510_add_on_nivs2011.zip
2. copy files in the folder named Custom Device llbs into <Public Documents>\National Instruments\VeriStand 20xx\Custom Devices
   copy files in the folder named Display Templates into <Public Documents>\National Instruments\VeriStand 20xx\Display Templates
3. open NI VeriStand and use PXI-2510 as a custom device.
4. deploy and open workspace. the default station of fault channels is pass through with dut channels. but when I change its station into an open state, PXI-2510 has no reaction.
Please help me with the problem.
Best wishes.
(6,397 Views)
by the way, name of custom device I use is as same as card name in MAX.
(6,392 Views)
Accepted by topic author MoonChen
If you use the console viewer (tools -> view console), do you see any error messages published to the screen?
Stephen B
(6,379 Views)
Hello Stephen,
Thanks for your reply. I did what you suggest and find an error -200055. Then I search it in ni.com and find the problem-I use a dashes in name of my card in MAX.
well, I got this-http://digital.ni.com/public.nsf/allkb/E180150CE00F8A08862578ED00368929
also, thank you very much for help.
Moon Chen
(6,366 Views)
