VeriStand
NI Veristand 2019 : System Definition
Why am I not able to right click on Aliases or any object under System Definition tab for that matter to edit it? I have not deployed my project and I am trying to edit and see directly from the System Definition window.
Thank you!
(648 Views)
Have you opened up the Configuration window and use that to edit?
(633 Views)
Thank you for prompt response, yes I was able to edit through Configuration window but I was trying to figure out why I am not able to right click on my System Definition window?
(626 Views)
Accepted by topic author krshah
It looks like this feature is not available in 2019, you have to use the Configurator.  In 2021, it looks like you can do some editing in the UI.
(604 Views)
I see, thank you so much!
(600 Views)
