VeriStand
Lambda Genesys DC Power Supply
I am trying to implement Lambda Genesys DC Power Supply custom devices , I have pxi 8108 with pxi1042Q ,and Lambda Genesys DC Power Supply, do I need any other hardware to communicate with power supply
(6,202 Views)
Hi Siddharth,
I see that Lambda Genesys DC Power Supply supports RS232/RS485 communication standard. If the model of programmable power supply that you have also supports RS232/RS485 communication then you need to have a PXI serial interface card.Please click here to browse  various available options.
(6,192 Views)
NI PXI-8108 RT Features
CPU
Intel Core 2 Duo T9400 processor (2.53 GHz dual core)
Dual-channel 800 MHz DDR2 RAM, standard
1 GB (1 x 1 GB)
Dual-channel 800 MHz DDR2 RAM, maximum
4 GB (1 x 4 GB)
Storage, hard drive minimum 80 GB SATA
Storage, solid state Optional*
Hard drive (standard option), minimum
80 GB SATA (5400 rpm)
Hard drive (extended temperature and 24/7 option), minimum
10/100/1000BASE-TX (Gigabit) Ethernet ports
1
Hi-Speed USB ports
4
GPIB (IEEE 488) controller
Serial port (RS232)
Parallel port
ExpressCard/34 slot
Watchdog/trigger SMB
Can we use RT controller serial port for communicating with power supply
(6,186 Views)
