VeriStand
Labview code to veristand model
Hi
Im converting a lab view code to veristand model, To be specific, its a UDP receiver which checks the port and gives data.
Im fairly new to this, so i have the following doubts
-In the receive UDP code, i have Init UDP, read and close, so when i build a model, every time the int and close will be called?
I need a model in veristand which will receive UDP data, which means i will be sending UDP data from another application like lab view or python.
I have attached the code to be made model
can some one give a thread to start developing?
Another approach would be, does veristand has inbuilt udp communication frame? if yes how can we configure that?
I could see a github project on custom engine, but i dono if im allowed to use it
(1,333 Views)
Yes. That's why you should not use a model for UDP communication.
VeriStand does not have a built-in UDP feature but allows custom plug-in via custom device. You should use the UDP-Data-Link Custom Device.  All custom devices on the VeriStand Addons github page are open source and free to use. However they are not officially maintained and supported by NI.
https://tmesystems.net/
(1,307 Views)
