VeriStand
LV Model and local variable / Property Node
I am working with a model written in LV. The previous ones I used work fine so far, but this latest one is a little more complex and seems to have some initialization issues. Basically from one run to the other the output are inconsistents. They are correct after the first time VS runs after booting up, but remains wrong after this, even if I re-deploy... weird.
It dawned on me that the VS dll must have the front panel removed at run time, what would be the implication of using local variables or the value propety node with this in mind ?
thx
L.
(6,111 Views)
Hello BSI,
Your guess about the Front Panel sound right to me.
Do you use Control Design & Simulation or LabVIEW core only?
Can you replace the local variables with Feedback Nodes?
Have good day,
Flo
(5,923 Views)
