VeriStand
Install VeriStand on CompactRIO
I am trying to install VeriStand on the hardware cRIO-9030.
I have installed VeriStand 2020R6 and LabVIEW 2021 on my PC. Then I did the procedure "Add/Remove software" from NI MAX to install VeriStand on the cRIO-9030, but I can't find NI VeriStand Engine in the list of the software to be installed on the target.
Which could be the problem?
(2,071 Views)
Hi ValentinaMassa,
VeriStand 2020 R6 only supports LabVIEW 2020 -- that's most likely your issue.
We are planning a VeriStand 2021 release coming in February next year -- that will add support for LabVIEW 2021 -- but will also be making the jump to supporting the 64-bit version of LabVIEW for the first time. Because of this jump to 64-bit we have released more VeriStand 2020 releases than we would normally when locked into a major version of LabVIEW.
Darin Gillis
NI - Chief Product Owner - VeriStand
(2,060 Views)
