VeriStand
Hardware platforms supported for NI VeriStand for windows deployment target
For a DAQ only VeriStand application hosted on Windows, are the following hardware products supported for scanning at the PCL rate?
PXI/SCXI
ethernet cDAQ
ethernetRIO
That is, can all the IO modules/types be found/enumerated and used by an NIVS project targetted to windows for these kinds of hardware?
(5,829 Views)
Hey Marlbuff,
Here are the pages from VeriStand Help that point to all the supported hardware. You can extend the support of VeriStand by using LabVIEW and creating a custom device if you'd like to use a specific hardware device that isn't already supported.
VeriStand NI Supported Hardware
http://zone.ni.com/reference/en-XX/help/372846G-01/veristand/supported_ni_hardware/
DAQ Devices supporting Hardware Timed Single Point
http://digital.ni.com/public.nsf/allkb/B4E831774F29FB038625754C0081C050?OpenDocument
Custom Device Developer Guide
http://www.ni.com/white-paper/12712/en/
Kyle Hartley
Senior Embedded Software Engineer
(5,808 Views)
