VeriStand
GetIWorkspace2 failed with "Exception has been thrown by the target of an invocation"
I deployed Engine Demo to `localhost`.
Based on https://www.ni.com/docs/en-US/bundle/veristand-net-api-reference/page/vsnetapis/c_exec_deploying.htm...
I wrote my code:
using NationalInstruments.VeriStand.ClientAPI;
class Program
    static void Main(string[] args)
        // The path to the system definition file and the IP address of the target
        string systemDefinitionPath = @"C:\Users\Public\Documents\National Instruments\NI VeriStand 2024\Examples\Stimulus Profile\Engine Demo\Engine Demo.nivssdf";
        string gatewayIP = "localhost";
        // Initialize Factory class instance to access NI VeriStand system
        try
            Factory facRef = new Factory();
            Console.WriteLine("Factory created successfully");
            IWorkspace2 workspace = facRef.GetIWorkspace2(gatewayIP);
            Console.WriteLine("Workspace obtained successfully");
            // Connect to the system and deploy the system definition file
            workspace.ConnectToSystem(systemDefinitionPath, true, 60000); // ms
            Console.WriteLine("Deployed system.");
        catch (Exception ex)
            Console.WriteLine($"Error type: {ex.GetType()}");
            Console.WriteLine($"Error message: {ex.Message}");
            Console.WriteLine($"Error stack trace: {ex.StackTrace}");
Based on the log, you can see Factory created successfully, but then failed with error:
Error type: System.Reflection.TargetInvocationException
Error message: Exception has been thrown by the target of an invocation.
Error stack trace:    at System.RuntimeType.CreateInstanceOfT()
   at System.Activator.CreateInstance[T]()
   at NationalInstruments.VeriStand.ClientAPI.ClientServerManager`1.GetClientServer(String address)
   at NationalInstruments.VeriStand.ClientAPI.ClientServerManagerInstances.GetDataServices(String address)
   at NationalInstruments.VeriStand.ClientAPI.WorkspaceImpl..ctor(String address)
   at NationalInstruments.VeriStand.ClientAPI.WorkspaceAggregator.Create(String address)
   at NationalInstruments.VeriStand.ClientAPI.Factory.GetIWorkspace2(String gateway_ip_address)
   at Program.Main(String[] args) in C:\Users\Hongb\Documents\Git\ConsoleApp1\ConsoleApp1\Program.cs:line 18
 Any guide would be appreciate, thanks! ☺️
(204 Views)
Accepted by topic author Hongbo-Miao
I got some guide at Stack Overflow and posted my answer at https://stackoverflow.com/a/79179785/2000548
Here is a copy:
Based on the error missing `System.ServiceModel.NetNamedPipeBinding`, I realized this has to be a .NET Framework 4 app instead of .NET Core 8 app, here is full working code that deploys "Engine Demo" to the gateway at localhost
namespace VeriStandController
    internal class Program
        public static void Main(string[] args)
            string gatewayIp = "localhost";
            Factory factory = new Factory();
            IWorkspace2 workspace = factory.GetIWorkspace2(gatewayIp);
This code now can succeed deploying the "Engine Demo" in the VeriStand.
(170 Views)
