I'm trying to implement the Lambda Genesys DC Power Supply Custom Device in Veristand.
I'm trying to understand/implement a couple of things.
1. I need to be able to set the output mode and the output value not just the limits.
Does this device just lack these (seemingly very basic) functions? Or am I missing something.
2. I need to drive 2x power supplies wired in parallel. My current method is to drive both devices by the same channels. I think this should work.
3. Regarding #1: if it doesn't support output values, I want to edit the custom device. I can get into the Libraries and get the source code. However, It would be ideal to get the un-compiled custom device project that was used to create the device. Is this available somewhere?
