VeriStand
Error -307850
I am trying to run a lvmodel in veristand with my computer and I have this error
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error -307850 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
NI VeriStand:  The target cannot be reached. Verify that the Ethernet cable is connected to the real-time (RT) target and that the RT target is enabled and running.
NI VeriStand:  Server TCP Interface.lvlib:TCP Connection Manager.vi:1
<append>=========================
NI VeriStand:  A communication failure occurred while handshaking with the target.
Target: Controller
• Shutting down VeriStand PC Engines...
• Unloading System Definition file...
(5,743 Views)
Hi Aim99,
Have you made sure the IP address in the system definition file is the right one (localhost for deployment on your PC, or the remote RT target with NIVS installed) ?
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(5,721 Views)
Yes in the system definition file i have localhost
(5,713 Views)
