VeriStand
Digital Waveform Graph
I just tried the Digital Waveform Graph add-ons, found here.Taking a closer look at it, it turns out this add-on only displays analog data as if it was a digital wfm, but does not seem to deal with real digital waveforms. Does this mean the digital wfm graph is not supported?
Thx.
L.
(6,034 Views)
How are you generating your digial waveforms, because from what I understand, and according to this KnowledgeBase, Digital IO is only supported through static IO. The digital waveform graph custom device does seem like it works for analog data that you set a threshold for to generate the graph.
Stephanie A.
Americas Marketing Manager
(6,012 Views)
Well... This is all before I realized Veristand does not support high speed DIO. So the graph showing digital output from analog signal is nice, but not helping in our case since it only deals with analog signals, intrinsically.
Thx.
L.
(6,005 Views)
Internally, VeriStand stores every channel as a LabVIEW DBL.  The custom workspace object can be modified to do a != 0 compare on VeriStand channel to make it compatible with digital data.  (Still no "real" waveforms though).
(6,001 Views)
