10-21-2011 01:37 AM
I want to use NI VeriStand FPGA-Based I/O Interface Tools in my programme. The programme runs OK in LabVIEW and Iget the signal I want. However, when I integration into NI VeriStand and deploy it, it shows me an error:
Actually my target is running normal. How can I solve this?
The accessories are my programme and what is in NI VeriStand.
10-21-2011 09:04 AM
There may be multiple problems, but this is at least one of them. Your FPGA code writes one packet and reads eleven packet, but your .fpgaconfig XML specifies you're reading 12 packets and writing 11 packets.
Also, of those 11 packets you're specifying, you're only using one. So you should change that constant on the for loop to 1 and change your XML to read 1 packet and write 1 packet.
10-23-2011 11:50 PM
Thanks. I will try and reply you the result.
10-31-2011 12:38 AM
hello.
i tried your advice, and now i can deploy and get the right wave. However, there is a new problem. The outputs doesnot change when i modify the input. What can i do to solve this?
i give you all my project, including project in labview and configuation in veristand.
Thank you.
