06-26-2012 04:35 AM
Is there any way to display the current date and time on the workspace window?
Solved! Go to Solution.
06-26-2012 09:58 AM
Are you referring to the date and time on the Windows host PC?
06-26-2012 10:36 AM - edited 06-26-2012 10:37 AM
Attached is an example control that you can add to the Workspace to display the date and time on your host PC. I created it by following the instructions on this page. If you want to make any modifications or customize it further, that document can help you get started. I based it off the Decoration - Free Label template, so that I could completely customize the behavior of the control.
To use this control, simply copy it to <Common Documents>\National Instruments\NI VeriStand 2011\Display Templates.
06-26-2012 09:36 PM
Thanks Jarrod
Thats what am talking about. And which page are you referring to?
-SID
06-26-2012 10:03 PM
It's hyperlinked. Click on "this" in "this page" in the response above.
