VeriStand
Date and Time display on Workspace
Is there any way to display the current date and time on the workspace window?
(6,826 Views)
Are you referring to the date and time on the Windows host PC?
Jarrod S.
(6,821 Views)
Accepted by Siddharthan
Attached is an example control that you can add to the Workspace to display the date and time on your host PC. I created it by following the instructions on this page. If you want to make any modifications or customize it further, that document can help you get started. I based it off the Decoration - Free Label template, so that I could completely customize the behavior of the control.
To use this control, simply copy it to <Common Documents>\National Instruments\NI VeriStand 2011\Display Templates.
Jarrod S.
(6,817 Views)
Thanks Jarrod
Thats what am talking about. And which page are you referring to?
-SID
(6,808 Views)
It's hyperlinked. Click on "this" in "this page" in the response above.
Jarrod S.
(6,803 Views)
