Can you please replace the "Get Fault Value" VI with the "Get Custom Device Channel Data" VI and access the "Channel" cluster value for access to the value "Faultable"?
The order of executing is described in the following article under primary control loop:
Thanks for your reply. Get Custom Device Channel Data is used to check if the value faultable. What i wanted to know is, "Is the value faulted?" and "If the value is faulted, how to clear it?"
Since the .NET API doesn't work in RT-Engine, so custom device i sent you will only work if running on the same PC.
Still looking for help...................................
