09-30-2019 09:38 AM - edited 09-30-2019 09:39 AM
After upgrading my PXI Real-Time Sytem (RTS) from VeriStand 2011 to VeriStand 2019, I am not able to deploy my program from VeriStand 2019 to the upgraded RTS. The error message I am encountering during the deployment-state in VeriStand 2019 is, that there is something wrong with “WebDAV”. The background is, that during the deployment-state there is a pop-up window named “WebDAV Login”, which requires a admin-username and a password, which I am entering but VeriStand is denying it.
To resolve this issue I have tried to follow the instructions stated on this website: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PlESAU&l=de-DE, but there was a again an error message, which is denying the username and password.
Hence, it seems that there is a connection-error with my PXI, but the strange thing is that it appears in the NI MAX program and there I am able to logon by entering username and password.
Another thing which I am recognized is, that I am not able to get a connection with the webserver of my PXI, while trying to reach it with my Chrome or Internet-Explorer browser. Always there is a message appearing to install Microsoft Silverlight, but this add-on is already activated in my browser.
09-30-2019 07:26 PM
Hello, have you already updated NI software in PXI controller? For example, NI driver, NI VeriStand engine, etc...
The version of those software should be same on Windows.
I guess it's caused by version compatibility problem.
10-01-2019 08:59 AM
All the stated problems arose also with an updated PXI-System. Hence the VeriStand SW on the host PC was updated and the PXI. Now I have even reset the whole PXI in order to counteract some upgrading issues and I have set up my system from "scratch", hence from a formatted PXI system but the stated problems remain.
10-06-2019 09:42 PM
01-13-2020 03:32 AM
Good hint but the solution to solve my problem consisted of two steps:
1. Installation of right VeriStand Version together with the correct packages and the right X-Net Database (related to my VeriStand-Project) installed on the real-time-systems.
2. Correct router setup with right port-forwarding adjustments inside my router. I could find the ports which VeriStand and the MAX uses with the tool "Wireshark".
