VeriStand
Connect to System: Error 7 Trying to Deploy System Definition Using Gateway.dll
If you receive Error 7 from Connect to System while using the Gateway.dll, it's because the VeriStand Data folder is not adjacent to the EXE.  While in the development environment, the EXE is LabVIEW.exe.
(2,814 Views)
I read and took this code (callVSGatewaySilent) in this post: https://forums.ni.com/t5/NI-VeriStand/Is-there-a-possibility-to-start-the-VeriStand-2011-SP1-Gateway...
I changed the Current Directory to "C:\Program Files (x86)\National Instruments\VeriStand 2018" with Environment.CurrentDirectory, before launch the Gateway. It starts correctly and I can retrieve the handle with GetIWorkspace2 method, but when I use ConnectToSystem method (http://zone.ni.com/reference/en-XX/help/372846M-01/veristandsdapi/html/m_nationalinstruments_verista...) an error occurs (error code 7).
The ConnectToSystem method is not the problem, beacuse if I launch my code from this path "C:\Program Files (x86)\National Instruments\VeriStand 2018" it works (no error).
The problem could be the setting of the current directory?
Francecso
(2,284 Views)
