08-19-2010 12:53 PM
I've created a Simulink model with some Gain Blocks and Constants. I would like to be able to access these parameters/values and adjust them using the Calibration manager in VeriStand. I created an .m file with the names and values I would like to use and updated the model blocks to use these names. When I import the model DLL in to VeriStand, I don't see my names under the model parameter section but rather what seems to be the simulink defaults. For example I see Gain1 with value of Gain. What I expected to see is Gain1 with the variable I entered in the Gain block such as Ke_Scaling1. Can anyone shed some light? It should be similar to the VS tutorial but there isn't an associated .mdl file in the Solutions.
Solved! Go to Solution.
08-21-2010 12:50 PM
Try compiling the model with "inline parameters" set in the RTW Optimization options. You will have to pick which params with the button there as well
08-23-2010 09:18 AM
That did the trick! Thanks.
