VeriStand
CAN Event Remote Frames
I've got a device that uses CAN Event Remote frames to retrieve data from the unit. Everything is functioning properly and I can request and read in the information through the XNET bus monitor but I haven't found a way to have Veristand handle the Event Remote frames (ie send out the request). Does Veristand natively support these frames somehow? I'm using Veristand 2016.
I can do a model or custom device but I was hoping for a built-in solution. Thanks!
(2,967 Views)
I am facing the exact same issue as barkermp ...
Using Veristand 2023.
Searched the net for document or examples, but came up dry. Can anyone please shed some light on this?
Or have you figured it out in the end, barkermp ?
thanks.
PJ
(553 Views)
