In a sequence file, when setting a parameter variable equal to a local variable, what's the difference between using 'expression' or 'assignment' ? Is assignment for only the value at the time that line of code is executed, and expression for continuous updating? Thanks.
The difference is only cosmetic. Assignment is just an expression with an assignment already typed into the text field. It was really only for educational purposes.
