VeriStand
Access signals of VeriStand project which is deployed to PXIe RT system.
Shared signal(variables) between VeriStand and another windows application, e.g. Labview?
for example, Veristand is deployed to a PXIe RT system. CAN messages are read from CAN bus of PXIe system CAN device. is there a way, can labview application have access these signals dynamically? Run both LabView and Veristand together.
(2,509 Views)
You can explore this palette -
(2,456 Views)
Thank you so much for the help! It solved my problem!
(2,446 Views)
