VXI and VME
how do i read the firmware version programmatically
specifically for VXi controllers master and slaves(MXI2)
(8,990 Views)
When you are using a MXI-2 interface your computer is the controller. The PCI-MXI-2 (master) and VXI-MXI-2 (slave) devices are just bus extenders and therefore have no firmware. They have a configuration EPROM which stores data, but this is not firmware and therefore has no version. Basically, there is no firmware to read.
Best Regards,
Justin Britten
Applications Engineer
(8,990 Views)
thanks for the infomation
(8,990 Views)
I assume "no firmware" on master/slave devices is only in a MXI system.
Due to obsolescence we are using the VXI-MXI-2 in its slot-0-controller function (not actually for MXI), I assume there's got to be firmware, and that your "configuration EPROM stores data, but this is not firmware" note applies only to MXI bus functions?
(7,624 Views)
