VXI and VME
What is root cause of Error in InitVXI library. Allocation error in initialization?
The error result after executing ResMan;  Error: Error in InitVXI library. Allocation error in initialization.
Hope you can help, thanks....
(6,423 Views)
Hi ctapa,
If by chance you receive this error when attempting to run ResMan outside of Measurement & Automation Explorer (MAX), then you will want to refer to this KnowledgeBase article, which details how to fix such an error/crash.
Curious--what operating system do you run for your VXI system? Also, what version of NI-VXI do you have installed? (You can check this in MAX, beneath the Software tree) In addition to the "Error in InitVXI Library..."  message you receive, do you see your system exhibiting any of the problematic symptoms mentioned here? Replying with any additional information on your system and setup would be most welcome and aid in finding the cause of the issue.
Kind regards, and happy holidays!
Warm regards,
pBerg
(6,401 Views)
