There aren't any known issues with what you are describing, so it could be many things. The 850c controller is definitely an older controller, so speed considerations may be the issue here. If this is a brand new application, then that could very well be the problem and slowing down the programs performance may be the answer. If this app. has worked in the past then you can bet that we are probably looking at some sort of hardware failure or bad software configuration. I have poured through all current and archived documents here and nothing similar comes up. The problem seems isolated, so continued troubleshooting is the best approach here. If I can come up with anything more specific, I will be sure to update this immediately.
Best Regards
Jeremy R.
NI - Applications Engineer
