08-12-2010 09:25 AM
Hi all
Resman is held up when it tries to configure the mainframe corresponding to the VME-MXI-2 device.
I am unable to load the hardware configuration for the device (-102).
The settings of the cards are the factory settings. However I believe I changed the requeted memory from 16k to 4k and that is the card and resman started having problems. Please help me.
EliAlca
08-13-2010 04:47 PM
Hi alcaEli,
Have you tried to configure the VME interface back to the 16k memory to see if this helps?
Best,
09-30-2010
09:05 PM
- last edited on
01-25-2026
02:00 PM
by
Content Cleaner
EliAlca- why did you change the requested memory size? Did you install DRAM? I think you should check out the VME-MXI-2 User Manual (start at page 183).
Hope this helps! Go State!
