VXI and VME
TLA APplication and NI VISA
I am using LabVIEW 8.2 and NI MAX 4.1
I am using Tektronix TLA7016 with TLA Application 5.1 SP1. In NI MAX I added VISA TCP/IP resources with IP address of TLA. It detects Mainframe and all the modules of the TLA. But while I open TLA Application, TLA APplication does not reconise TLA modules! Does any body use this and found some solution for this? Could you please help me?
Vishal
(6,273 Views)
Hi Vishal,
I assume you are using TekVISA in addition to NI-VISA. Correct? If you delete the TCP/IP resource from MAX, are you then able to access your TLA modules using the TLA application? I notice you posted in this thread; Are you still having trouble even with just one vendor's VISA installed? Also, does the "switching" utility you mentioned get rid of this issue? Thanks!
Message Edited by _Belle on 04-23-2007 04:58 PM
Ebele O.
(6,256 Views)
