VXI and VME
Slot 0 boots but VXI bus hung my which module?
slot 0 controller (Dy4 CCA) boots and after boot I can rlogin and see slot 0 controller is still trying to run scripts to load each of the VXI boards. I removed the boards systematically and rebooted to find the board that was hanging the VXI bus. Is there any way to find the bad board using software so that I don't need to pull boards and reboot?
Thanks, Eslacker
(6,876 Views)
I presume you are wondering about this for future reference as you seem to have found the problematic board. If a board hangs the bus, I don't know if there is a good indicator just prior to hanging; in general, the bus should not hang and you should not have this problem with your good instruments!
Thank you,
JLS
Best,
JLS
Sixclear
(6,863 Views)
