VXI and VME
My VXIpc-872B does not see my external VME genereated iterrupt.
when using VXIint.c installed with VIC the external interrupt is not seen. When VIC is used to generate an internal interrupt on the same line this is seen ok.The same set up works fine on the VXIpc-870A (also known as the E9850A from Agilent)
(5,871 Views)
Greetings,
There may be some additional information that is needed in order to understand or troubleshoot the issue. What versions of NI-VXI are being used with the two controllers? Is there any way that you can determine whether the DSP board is actually asserting the interrupt line or not? Have you possibly created any SPY files for the communications?
Answers to these questions may be helpful in determining why there is any issue.
Patrick R.
(5,871 Views)
