VXI and VME
Max VXIpc-850 Hard Drive
What is the largest hard drive size supported by the VXIpc-850 BIOS. (and what is the most up to date version of the VXIpc-850 BIOS?)
I am trying to replace a dead hard drive in my VXIpc-850 (5 GB). I dont want to put a another used one due to the likelyhood of it dying.
It looks like I can only buy New 10 GB, 20 GB, 30GB+ drives online.
I would also like to put the biggest hard drive inside of the unit that I can.
Any help would be greatly appreciated!
(6,082 Views)
Hello reichenbach,
I'm investigating your inquiry and will provide an update.
Ali M
(6,067 Views)
From the information I have gathered, NI has only tested and supported HDD's that ship with the controller. If you would like to use a larger HDD, you can try this, but know that you may need to partition accordingly. Using a different HDD is not supported by us, but may work.
Ali M
(6,051 Views)
