Marcus,
The most common cause of problems with MXI-3 systems is simply not using the correct boot order. I would first verify the proper boot order (chassis first, then computer). Verify that the LINK LED comes on right after the computer boots, and that the LINK LED never, ever, blinks or strobes during operation. If the LINK LED goes out, strobes, blinks, etc, then a hardware problem with the link (PCI-MXI-3 board, PXI-MXI-3 board, or cable) is indicated.
If you continue to have blue-screens at boot, then the next step is to "divide-and-conquor" the system. What we want to do is make sure that none of the cards in the PXI (or CompactPCI) chassis are themselves causing the problem (for example, if a card has a resource conflict). For troubleshooting purposes, remove all cards from the PXI chassis, shutdown, and then power-up again with the proper boot sequence (chassis first, computer second). If the problems disappear, then a problem or resource conflict with one of the PXI / cPCI cards is indicated.
If the blue-screens continue, even with the hardware removed, then the next step would be to uninstall the MXI-3 Optimization software. What we are going after here is if it is during the run (every time at boot) of the MXI-3 optimization software that the blue screen occurs.
If none of these indicate the problem, then the "divide-and-conquor" approach requires us to determine if the problem is with the MXI-3 kit itself, or something specific to that computer. Two things to try. The first is to try the MXI-3 kit on a different machine. The second is to try another MXI-3 kit (if available) with that machine.
Through these steps, you should be able to isolate a single piece of hardware (a PXI card, the MXI-3 kit, the PC, etc) that is common to the problem.
(note, the bug referred to by Katie was specific to running the MXI-3 optimization software, not the MXI-3 hardware in general - so if you are seeing the problem she referred to, you should see the blue-screens disappear when the MXI-3 Optimization software is uninstalled).
As always, National Instruments Technical Support is only a phone-call away (7am - 7pm CST) if you want to work with a NI engineer on this procedure.
Greg Caesar
