VXI and VME
Letter of Volatility - VXI-PCI8026
I work in a secured area and we recently purchased 2ea of the VXI-PCI8026.  Can someone direct me to a Letter of Volatility for the EEPROM on the VXI-MXI-2 and PCI-MXI-2 module/board?  Also, what exactly is the size of the EEPROM, I couldn't find this mentioned anywhere in the manual.
- Darin
(9,004 Views)
Darin,
Thank you for using the Forums.  I believe the document that you are looking for can be found here.
I hope that helps.
Brian P.
Applications Engineer
(8,994 Views)
Hello Brian,
Thank you for the quick reply.  Does that Letter of Volatility apply to the VXI-PCI8026 also, even though it states it's for the VXI-PCI8015?  If that's the case, I'm assuming it applies to any VXI-PCI80xx and that the only difference between the VXI-PCI8015 and VXI-PCI8026 is the software package that ships with the module and board?  Is that correct?
- Darin
(8,991 Views)
Accepted by topic author DarinM
Darin,
You are correct, I have checked the part numbers for both boards and the actual letters of volatility and they are the same.  I am sorry for the confusion.  I hope that cleared it up.
Brian P.
(8,987 Views)
Excellent!  Thank you very much!
- Darin
(8,984 Views)
