VXI and VME
Installation of Visa on Opensuse 10.2
Hello Matthias,
Thanks for that location, I have downloaded and installed but the result is no better -
LinuxSuse:/usr/src/linux-2.6.18.8-0.9 # rpm -qa | grep kernel
kernel-source-2.6.18.8-0.9
kernel-default-2.6.18.8-0.9
kernel-syms-2.6.18.8-0.9
linux-kernel-headers-2.6.18.2-3
They are still not exactly the same numbers.
LinuxSuse:/usr/src/linux-2.6.18.8-0.9 # uname -r
2.6.18.8-0.9-default
However, when I run the make commands have have exactly the same missing files.
Roger
Message 11 of 13
(4,601 Views)
Hmmm, stdio.h or strings.h are anyway not really
kernel files.
Maybe you are missing: glibc-devel-2.5-25.i586.rpm
Matthias
Message 12 of 13
(4,594 Views)
Matthias,
Thank you very much, that was the answer I was needing.
I loaded that file and the make commands then ran without error. I then started the install of Visa and other than a warning about
******************************** WARNING **************************************
* The version of gcc in the path does not match the version of gcc used to    *
* compile the currently running kernel.  This can cause unpredictable         *
* behavior in kernel drivers and should be fixed.                             *
* gcc version: 4.1.3                                                          *
* kernel compiled with: 4.1.2                                                 *
it continued and completed the installation.
Now all I have to do is see if it works!
Roger
Message 13 of 13
(4,592 Views)
