VXI and VME
I Require an Example for Message based communication in VXI using LabVIEW
I'm trying to use Tektronix/CDS 73A-453 for sending data to a remote terminal through MIL-STD 1553b. Please give some examples in this, as I am unable to start the project without knowing these basics. Thank You.
(6,999 Views)
If you are using LabVIEW or LabWindows/CVI you can find a driver for this instrument at this website. Select Tektronix/CDS as the manufacturer and enter 73A-453 in the Additional Keywords and hit go. This will bring up the two drivers. When you install this on your computer put it in the following directory:
C:\Program Files\National Instruments\LabVIEW 7.1\instr.lib
If you place it here the functions will show up in LabVIEW if you go to the Block Diagram's Functions Palette>>Instrument I/O>>Instrument Drivers. This should get you started. If you have more questions please repost.
JenK
(6,988 Views)
