I will use the HP1432A to measure the cylinder pressure in an internal combustion engine. In this case, I have to use the external trigger and the external sampling rate. I downloaded the Labview driver for the HP1432A. Unforturately, there is no example code. I wonder if somebody had the experience of using the HP1432A. If yes, please help me out!! Thanks a lot!
I would recommend contacting the manufacturer of the device since NI did not create the driver. The download for the E1432A on our website is merely a LabVIEW wrapper for the actual driver. Here is the readme for the driver from Agilent's website:
