09-21-2015 06:54 PM
I'll start this out... if this ends up the wrong place we can close or move.
I've on occasion wished for another function to be added to <vi.lib>\addons\analyzer
_analyzerutils.llb
I end up writing it, but thought it should be included for others.
Maybe this can become a suggestion place for these items.
Might be duplicating idea exchange, but I think this might be a little better focused with the right audience.
Post what you write that you think is great.
Post what you wish were there.
09-22-2015 12:15 PM
I like this idea. I'll start:
Is owned by typedef.vi
Given the reference to a control or constant, this VI will tell you if that object is owned by a typedef. This helps when trying to filter results for a VI Analyzer test when there's nothing the user can do to fix that particular failure object (since it is owned by a typedef).
I am planning on shipping this VI in _analyzerutils.llb in LabVIEW 2016.
One thing that is unfortunate about the NI Community forums is that I can't attach a copy of the VI to this reply for y'all to review...
09-22-2015 12:30 PM
Here's the one I'm working on:
_Analyzerutils.llb (LV2012 here) contains a VIAnUtil Check If ErrClust.vi
Works great for just a singleton error custer wire.
I'm making a version that has a "IsErrClust?" output as well as an "IsErrClustArray?" output to let me know if the item is an error array.
Could be two different VIs, but I chose to just do two outputs of the same VI.
09-22-2015 12:32 PM
I think you can attach files if you choose the "use advanced editor" upper right corner of the reply window.
09-22-2015 12:34 PM
Ah, you're right! Here's the Is owned by typedef VI, saved in LabVIEW 2015.
09-23-2016 01:33 PM
I've also had a need for a "is owned by array" similar to a "is owned by typedef"
09-23-2016 02:48 PM
Something like this? Saved in LabVIEW 2015. If it works the way you expect, let me know and I'll try to get it into LabVIEW 2017.
